Results 1 to 10 of 13
Thread: Mounting a winch in genuine bar
    Advanced Remdogg's Avatar
    Jul 2013
    Meadows SA
    Hey all
    I just bought a 2011 Y61 Patrol that has a factory steel bar and have tried fitting a winch but there is nothing to mount the winch on. Is there a cradle that i need to mount the winch on. There is a place for the fairlead but thats it. I have called a few Nissan dealerships and they said they have no idea.
    I need some guidance.
    Thomastown, Melbourne
    6 Post(s)
    Is it a winch bar mate???
    Jul 2013
    Meadows SA
    Yeh mate genuine winch bar. I think its called a deluxe bar.
    You'll have 2 captive nuts under chassis on both sides the winch "cradle "will bolt to that.
    Plenty for sale on Ebay, petrol or diesel
    Jul 2013
    Meadows SA
    Yeh they all say for alloy bullbar, so i take it that its the same thing.
    Expert Blownlc's Avatar
    Werribee Vic
    Don't they bolt to the rear of the bar? There should be 4 threaded nuts welded to a plate on the opposite side.
    LESS YAP YAP, MORE TAP TAP!!
    http://www.nissanpatrol.com.au/forums/image.php?type=sigpic&userid=8495&dateline=1347611  053
    6 Post(s)
    Photos mate... that helps
    Mine bolted straight in. Well upside down and flipped but bolted through the bar.
    Top 2 bolts through the bar above the fair lead hole and the lower 2 go through the fair lead and holds itin place as part of the mounting.
    Take off the lower plate cover from underneath and you should be able to bolt it straight up mate.
  10. The Following User Says Thank You to MudRunnerTD For This Useful Post:
    harrythomas (2nd August 2014)
  11. #9
    Werribee Vic
    Exactly. That's how I installed mine. It's a bit of a bitch to engage due to the positioning. I also have the genuine Nissan winch bar.
    As a point of interest, have a look at the compliance tag. You'll notice it states that only a warn xp9000 is to be fitted.
  12. #10
    I have fitted an x9 Super Winch off a 200series cruiser (Toyota factory fit winch)
