Results 1 to 10 of 17
Thread: Vic roads and 6.5 engine change
    Expert Ian2011's Avatar
    Sep 2011
    Australia
    Has anyone out there had any issues with Vic roads when trying to get their engine number changed for registration purposes, seems they don't recognise any paperwork issued by that mob that change engines in WA. Been told I need a VASS certificate and the whole vehicle inspected by some engineer at an unknown cost. PS, anyone know a inspector in Wodonga
    6.5 Chevy, roof rack, uhf, Spotties, dual batteries, ARB Bullbar, 12, 000lb winch, (unfortunately not Warn) Safari snorkel, Dieselgas conversion, 2in lift, engine watchdog fitted, boost/EGT guages, front elokka fitted, rear power supply mods, turbo timer, dual wheel carrier rear bar.
    your local RTA branch should know of engineers in your area, he'll need to inspect your 4x4 and then certify for any work done.
    ring first cause you may be in for a shock. prices of $4-5k not out of the question, let me know via PM if you get stuck.
    I take it you got no paperwork from Brunswick.
    Sep 2011
    Australia
    Only a blanket letter from the WA government that says the modification is allowed, apparently the closest engineer to me is in Towong, 80klm away and I don't he wants to look at it, we had a heated discussion after he said he needed to inspect all other modifications as well, and said my 2 in lift required an engineering cert as well. I did hear about the 5-6000 cost, seems ridiculous for someone to do an inspection. Not sure how you can help me out but any help is appreciated.
    330 Post(s)
    Be prepare to drive to Melbourne, it could save you a HEAP OF CASH!
    Give Brett a call at 4x4Obsession in Melton mate or John Bider at Biders in Cranbourne. Either will point you straight and be able to handle your Engineering.
    Good luck.
    Ian2011 (8th July 2013)
    Sep 2011
    Australia
    Just so happens I am going to Melb in a few weeks, this might just work out, thanks for your help Mudrunner
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Ian, this isn't much help as I am in Qld, but the process was straight forward here. It was inspected and approved, along with the long range fuel tanks, for around $200. Brunswick should be able to refer you to an engineer in Vic who handles their conversions regularly. I would suggest you check with them first. 5-6 grand seems way out for a vehicle inspection!
  9. #7
    Sep 2011
    Australia
    been on phone to brunswicks today ben, still waiting for them to supply that preferred engineer
  10. #8
    FNQGU's Avatar
    Jun 2013
    Cairns, Queensland
    21 Post(s)
    Not good mate. Did you get this resolved?
  11. #9
    Sep 2011
    Australia
    Yes, all sorted now. Got that nice blue plate and Vicroads are happy. Now I can put back all the barwork I had to take off to get the car down to a respectable weight, back on.
  12. #10
    Patrol Guru Irish's Avatar
    Who did you end up getting to engineer it mate?
