Now this is the hard part. If you have acess to a press use it it mite cost you a six pack at the local mechanic to use his as i said im out on my property & dont even have a dunny let alone a press. Ive set up the axle on timbers to support it via the bearing housing then i heated the housing for about 15-20 mins then using a block of timber & a copper hammer i held the timber on the axle end & hit it a couple of times & the axle slide out of the bearings. Im doing all of this on my own so it can be a bit hard to do it would be o lt easier with 2 ppl
