6th November 2012, 11:00 PM
#11
The Following 2 Users Say Thank You to megatexture For This Useful Post:
MudRunnerTD (22nd May 2013), skiman (24th May 2015)
6th November 2012 11:00 PM
22nd May 2013, 11:23 AM
#12
Black Irish with an English twist / Gypsy / Tattoo's and loaded full of Grumpiness.. I blog my paintings and other random bits on
Billy Bleed
22nd May 2013, 02:00 PM
#13
Moderator
Mega I like that ALOT!!
Did you take the box out to bolt an nut it in or are they just self tapping screws into the plastic??
That's great! I was going to use Velcro into the pen ledge and a dot behind onto the days to old the iPad in position in that slot but I like what you have done! You have no trouble changing gears and stuff?
Check out my Toy -->
Rogue Dung Beetle
22nd May 2013, 02:25 PM
#14
Travelling Podologist
MudRunnerTD
Yes I like it a lot too. Despite the Patrol being a large vehicle, space inside the front cab is pretty limited & difficult to find a spot for the ipad that doesn't get in the way or lend itself to a 'cluttered' feel.
Unfortunately for me the dash in my DX is different, I don't have that space between the two air vents, instead the two air vents take up the entire width.
What model Patrol is yours Mega? Maybe I could find one at a wreckers & do a switcheroo?
In the meantime my wife continues to hold the ipad which is mostly a better solution than many on the market.
Cuppa
22nd May 2013, 03:53 PM
#15
Moderator
Cuppa
Cuppa
Hey Cuppa you have a GUIII dash. Mega is a GUIV and completely different. Sorry mate
Rogue Dung Beetle
#16
I bought the same one as mego and it works a treat, still moves a bit but i fixed that by having the weight of everything on the wing nut inside the compartment so its got a solid base to rest on, works a treat.
22nd May 2013, 04:07 PM
#17
MudRunnerTD
Bugger! I guess I'll stick with my wife then, though I hardly dare refer to her as my ram mount.
At least it confirms that I have a GU III.
Cuppa
22nd May 2013, 04:13 PM
#18
brave man indeed Cuppa, brave man indeed , please confirm later that Mrs tea has read this.
with the Dx ute being "different", is it poss to make a small shelf across the top of windscreen
and make something that "flips down"
@ Mega what model is yours as that dash is different again series 4 ???
22nd May 2013, 05:06 PM
#19
Moderator
threedogs
Its a Series 4 and later 3D, he has fitted an after market Stereo.
Mine is identical to his. the glove box at the top that Mega has used is where they fit eh Factory GPS in the TI models Us plebs get the glove box.
Rogue Dung Beetle
24th May 2013, 08:10 PM
#20
MudRunnerTD
... the glove box at the top that Mega has used is where they fit eh Factory GPS in the TI models
Ha, that'd have to pee off the Ti owners who want somewhere to mount an iPad.
