Do they light up the bonnet when mounted on the roof?
Often wondered about the glare, especially as mine is white.
Macca
Yes they do but if your able to. Just move them further back.
Don't slap it, tap it!!!!
macca (23rd April 2013)
If its back enough you should get some shading from the roof over the bonnet.
There were a few in use during the night events at Tough Trucks, the light sure was bright, had a look around me and they certainly lit up the area. Very impressive
Macca
Are you still interested DX Grunt??? otherwise I will put it on ebay and it will be gone!!!!
you've got Pm
SHINY AND NEW: 2015 Series 2 Y62 Ti in White. Bone stock, hate to say it but its the wifes car this time.
OLD SOLD:Silver 50th Anniversary Patrol, 2" Pro-Comp Lift, 32" MT ATZ 4 Rib, 9000lb Warn Winch, UH7700NB + BT UHF Brilliant. Ultra Gauge and some GO FAST bits........
How many lumens is it?
Heres mine if it helps. Exact same one...
I tapped that app...
Normally 240 watts and around 14,400 lumens from memory
is it spot or spread beam or combo?? or 30 degree or 60 degree.
are leds Cree or epilstar??
i the only one seeing the specs?
240w 3w
intensity epistar LED's,
17a draw
6000k
12 degree spot beam and 60 degree flood
30,000hr life
taslucas (23rd April 2013)
