Great Southern Camping
When you start the truck, the switch in the centre console for "Auto, Hold, Power" will flash. Count the flashes and sometimes it may be a known TCU fault code (I had 16 flashes prior to box overhaul as have a couple of other people, and whilst I thought this was normal, it isn't - it was flashing an error code; it is now fixed, TC replaced and only flashes about 4 or 5 times and is running like a bought one).
Other than that, the 4th gear is overdrive, and I believe there is a switch for that (not the lever switch) below the stick in the cover, or on top of the box with the ATP switch. That would be a good place to start also maybe?
Odd about the first gear issue though - like it hasn't got enough oil flow/pressure when cold which could suggest incorrect oil type as stated already - what oil do you run? Fully synthetic?
Scotty (Bigrig)
