Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Share your Drawers with kitchen setup
    Legendary NP99's Avatar
    Feb 2013
    Broadford VIC
    Quote Originally Posted by Westy's Accessories View Post
    Mid way threw mine.
    Fridge will sit on top left, above a short draw for recovery gear and under that will be a pull out bench top / table, the on the right is the full depth food and groceries draw.
    Owner of
    Westy's Accessories
    What's the progress mate?
    43 Post(s)
    Re: Share your Drawers with kitchen setup
    Had a set back. The top sheet bowed a good 60mm. So its cut and ready to go, I've just had to wet it and try to reset the sheet s bit.
    Shift work is hard to get stuff done around. But on days after Easter so should be able to smash it out.
    Owner of
    Westy's Accessories
  4. The Following User Says Thank You to BigRAWesty For This Useful Post:
    NP99 (25th March 2013)
  5. #13
    Expert AJTich's Avatar
    Oct 2013
    Andrews Farm
    The pull out table is a cool idea, and easy to use...
    A&j
