Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Oil/petrol smell coming into cabin
    Hardcore
    central coast nsw
    Quote Originally Posted by Ducer View Post
    Thanks Robo, smell is definitely entering through the venting system. Didnt know about the varnish residue, will have a look and nup, mech said easy peasy to tune and it guzzles fuel at the best of times. Id be more worried if it didnt
    I see a spot for a bookie here somewhere. 3 say rocker cover, im going with oil/crap build up heating up... TBC!
    No wuckin furryies.
    just some info, some where, thing, to look at.
    all good.
    IF IT'S NOT A NISSAN.
    THEN IT'S A COMPROMISE
  2. #12
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Re: Oil/petrol smell coming into cabin
    Mines got a leaky rocker cover and I'm getting a burnt oil smell in the cab. Should be easy to visually check if your rocker cover is leaking.
    FanTapstic!
    Hello from Under Down Under!
  3. #13
    Advanced Ducer's Avatar
    Dec 2012
    NE Melbs
    Thx Lucas. Was leaking a bit up until a few weeks ago when it was all checked and tightened. Will have another look again after this weekend. Just had it steam cleaned so it should be fairly easy to spot.
    True that the it comes loose fairly easy?
    dave's 4x4 trips
    93 GQ Maverick with fun stuff
  4. #14
    Aug 2011
    North West Tas
    56 Post(s)
    Not sure how easy it comes loose. Mine has stayed tight since I tightened it a few weeks ago. I have degreased the area but there's still oil in behind the engine that I can clean out very well. I reckon that's where the smell is coming from. Heres a good test: when I degreased it, for a few days I could smell degreaser as well as oil fume so I reckon it's safe to say that's where the smell is coming from in my patrol.
    FanTapstic!
  5. #15
    Dec 2012
    NE Melbs
    Yeah right. Interesting. I havnt driven it since I had it steam cleaned but tomorrow I am taking it for a 120km drive so it will be interesting to see if the smell comes back or if any leaks appear. Ill keep you posted. I might tighten up the rocker cover before I leave. See if there's anything in it.
    Does your rocker cover gasket need replacing?
    dave's 4x4 trips
  6. #16
    Patrol Guru
    Apr 2011
    Melton
    Burnt oil smell is as per above - oil leaking from the rocker cover or else where an landing on the exhaust
  7. #17
    Dec 2012
    NE Melbs
    Took it for a drive on sat and today and so far no smells and no leaks. Fingers crossed that's sorted and it doesn't appear again. I will keep checking for leaks though
    Thanks again to all that have helped
    Cheers, Dave
    dave's 4x4 trips
  8. The Following User Says Thank You to Ducer For This Useful Post:
    Robo (5th March 2013)
