Thx Lucas. Was leaking a bit up until a few weeks ago when it was all checked and tightened. Will have another look again after this weekend. Just had it steam cleaned so it should be fairly easy to spot.
True that the it comes loose fairly easy?
dave's 4x4 trips
93 GQ Maverick with fun stuff
Not sure how easy it comes loose. Mine has stayed tight since I tightened it a few weeks ago. I have degreased the area but there's still oil in behind the engine that I can clean out very well. I reckon that's where the smell is coming from. Heres a good test: when I degreased it, for a few days I could smell degreaser as well as oil fume so I reckon it's safe to say that's where the smell is coming from in my patrol.
FanTapstic!
Hello from Under Down Under!
Yeah right. Interesting. I havnt driven it since I had it steam cleaned but tomorrow I am taking it for a 120km drive so it will be interesting to see if the smell comes back or if any leaks appear. Ill keep you posted. I might tighten up the rocker cover before I leave. See if there's anything in it.
Does your rocker cover gasket need replacing?
dave's 4x4 trips
Burnt oil smell is as per above - oil leaking from the rocker cover or else where an landing on the exhaust
Took it for a drive on sat and today and so far no smells and no leaks. Fingers crossed that's sorted and it doesn't appear again. I will keep checking for leaks though
Thanks again to all that have helped
Cheers, Dave
dave's 4x4 trips
Robo (5th March 2013)
