I think my faults occurred the same way as yours coldcomfort , but i could not replicate it deliberately .
Mine does it too. 2012 gu8. Very frustrating. Told Nissan about it, didn't get a Greta response. Service manager told me you do realize it has an electronic throttle.... Ah yes I do mate but what does that have to do with it... There is oviously a intermittent fault. Basically they tested it and said nothing wrong. Next morning sure enough did it agian.. Cannot replicate it no matter what I try.
The list of mods is long, the funds are short!
it could be unclean diesel, try other station next time you pump gas.
I seriously doubt fuel issues as it seems a lot of poeple have the exact same symptom. But I could be wrong.
It isn't doing it just from cold with the Pre-Heat Switch engaged is it?
Just thinking that it may be something computer related to the Pre-Heat Switching......
My car was always warm when it played up .
Well - we scratch that theory.......
Mine has never had an issue, so I'm just trying to find some common ground....
Mic
Mine will go at any time and won't go back to normal untill the motor is turned off for about 30 seconds and restarted the only way to get Nissan to see it was when I turned up, I called them let them know I was coming in arrived 10 mins before knock off and the tech was too busy to look and said come back later so I got a guy from behind the counter to try it then turned off the motor and started again then he said there was a problem so replaced the pedal assembly. We were trouble free for 6 weeks now its every 2 weeks it happens but they won't research to find the fault as no codes come up.
Jim
my gu9 2013 has just started to get the same problem it also starts to rev high about 2000 rpm at idle. its going to Nissan on Wednesday
hopefully they find something not holding my breath though
