can't get sub pump to work? sub tank light is staying on the dash got the sub light to flash randomly but not pump. transfer pump not working? after ideas.
Try disconnecting the battery for about half an hour. Sometimes the computer gets latched.
Steve
2011 Patrol Safari 4.8 (Fitek)
How full is your main tank. If its close to full it'll do that
Such is the rule of honour.
it would randomly flash every now and then when we pressed it but we only got that to happen 3 times. tank wasn't full it was under a quarter. will try disconnecting the battery. checked all fuses.
well disconnected the battery and low and behold the pump started working cheers guys.
its nearly worth putting an isolator switch in patrols.... the amount of problems just disconnecting the battery can fix.... make it easier then actually disconnecting the battery
wildgu6 (19th February 2013)
fixed that now fridge keeps blowing fuses need the weekend to suss it out seems like its got a exposed wire
