Been there done that to I'll PM Where I got my trailer stuff from not far off ring rd for you in Tulla
Disregard the 4x4 in the background, they were the DARK YEARS best not revisited
Was there the other day as the mob I use have moved and are still not set up........ I break trailers all the time and am on my third gardening trailer!!
Build a tuffer trailer in 1/8 checker plate, that one in pic [Blue} used to carry a Bobcat
PM sent
Don't weld drawbar to tub like my pic, just underneath both sides, smear silicon instead
Just worked out that the spring rate on the current slippers is 600KG. So going 750kg would be better...
Just going through these comments again and come to think of it, I have to really watch out I don't make the draw bar too long ad then I will be putting too much weight up front. Unfortunately I cant reposition the axles as the guards are already there. Maybe a water tank in the rear might be better to even things up a bit.
Yes that is a option.
Owner of
Westy's Accessories
Long draw bar for me always.... much better handling.
I have owned many trailers including 3 gardening ones and swear by a long draw bar.
Plus you get that room for tool box or something else.
Ok here are a couple of the axle/ shocks and tank setup.
Owner of
Westy's Accessories
Think I'm gonna have to call in the big guns to help flip here over. BA! Keep your phone on mate
When I had my camper built by Tambo Campers I had an 80lt water tank placed behind the axle and a 60lt tank I. Front of the axle. Works a treat
Bloodyaussie (13th February 2013)
