21st January 2011, 12:51 AM
how to improve gu auto gearbox
just found this click on the link
http://www.automatictransmission.com...sp?NewsId=8169
sounds like a good idear dont know cost though
stephen
OH LEATHER IS NICE
![](image.php?s=9890089ae2355af4845614208902f22c&u=256&type=sigpic&dateline=1352567496)
21st January 2011 12:51 AM
21st January 2011, 02:35 AM
Make sure you’re sitting down when you ring for a quote.
Most of us just change the 12 Ohm line pressure dropping resistor for a 1K or 2K 20W resistor which improves shifts for about $5.
21st January 2011, 07:04 AM
SUCH IS LIFE
Chaz
Agree with above. This little mod is a must in my book, no slip in gear changes and the box would probably stay cooler. I've gone with1k and suits my needs. Theres a few variances of resistors you can use.
Chaz, I believe you've done a diagram on how to wire it up??
________________________
______ 2017 D-Max _______
21st January 2011, 07:53 AM
I think this is one of Chaz's diagrams. This circuit lets you switch between the factory 12ohm resistor and (in this case) 1012ohm.
![](http://i758.photobucket.com/albums/xx224/tonyh01/Resistorcircuit_series.jpg)
Tony
21st January 2011, 07:54 AM
hi, does this mod apply to the GQ as well?
1981 Nissan Patrol MQ SWB, 3.3TD, West Melbourne.
21st January 2011, 08:00 AM
21st January 2011, 09:11 AM
YNOT
Tony
Yep, that’s the one Tony. I’m still using that setup and have found it useful when doing a lot of low range work. Some times it just shifts too hard with the 1K resistor in circuit, so switching back to the factory 12 ohm job makes it a lot smoother.
21st January 2011, 09:37 AM
looks interesting, where is the TCU located and is there a connector on pins 1&2 already with the 12 ohm resistor across them or is it something that needs to be added?
Many thanks
21st January 2011, 10:02 AM
boggy2006
Many thanks
Boggy2006,
You don’t need to access the TCU for this mod. Both wires are the 2 that go to the plug for the voltage dropping resistor.
The TCU is behind the passenger side kick panel.
The Following User Says Thank You to Chaz For This Useful Post:
21st January 2011, 02:39 PM
sorry to be dumb, I thought it was the ECU behind the passenger panel. And is the resistor somewhere close by?
Thanks again.
