Results 1 to 10 of 10
Thread: Service?
    Jul 2012
    Anglesea Vic
    Service?
    Hi Guys
    Just got our GU back from a service and the next day the sub tank warning light came on. Have done a search suggesting that I disconnect the battery, which I will do over the weekend, dont think the radio has a code!
    My question is could the warning light have anything to do with the service, my mechanic says its just a coincidence? but he would say that wouldn't he?
    Thanks for your thoughts
    Richard
    Thomastown, Melbourne
    6 Post(s)
    My mates did the same thing when he needed to do some small work and my mechanic just disconnected the battery and all good.
  4. The Following User Says Thank You to Bloodyaussie For This Useful Post:
    richardl (14th December 2012)
    Patrol Freak lorrieandjas's Avatar
    Brisbane
    Hi mate - unlikely to do with the service - what did you get done? Disconnecting the battery would be the go as you have suggested and as BA has mentioned as well. I don't know what causes it but seems to be a fairly common issue that comes up - maybe weird pump setup.
    Jas
    Disconnect the battery for an hour make sure the terminals are clean to, use a scourer pad. All should be good
    Western suburbs of Melbourne
    11 Post(s)
    It's funny how an electronic fault can be fixed purely by losing all power to the electronics to just reboot and start again.
    6 Post(s)
    I wish I could be fixed so easy!!!!
    Mate there will never be a cure for what you've got hahahaha
    DIAL-A-TAP
  10. #8
    Expert Thirsty's Avatar
    Oct 2011
    Raceview, Ipswich QLD
    As stated above, Disconnect battery. I put a long range fuel tank in and had the same issue. If they changed the fuel filter, that may have something to do with it. I put mine down to the fuel filter (4.5 petrol by the way) as we have done many long range tanks with out the issue.
    Troy
    1998 GU TI LS1
  11. #9
    Aug 2010
    adelaide
    no coded radio so that should be ok
    OH LEATHER IS NICE
  12. The Following User Says Thank You to my third 256 For This Useful Post:
    richardl (16th December 2012)
  13. #10
    Jul 2012
    Anglesea Vic
    Thanks Guys
    Finally got round to fixing the problem, disconnected the battery as was suggested and all is good.
    The service was just fluids and filters
    Richard
