Sorry NisHead its taken me a while to reply here.
Have a chat with Shane at Suspension Stuff in Brizzy.
I have never had any problems with the coils dropping out.
Phil
Phil
2010 GU7 Patrol ZD30 Manual - 33"KM2s - 2"lift - ARB front locker
Maxhead (1st November 2012)
What length shock are you running?
Owner of
Westy's Accessories
2 inch lift but using variable rate coils. I think they are King branded
The shocks are OME brand and are 4 inches longer.
I bought it as a matched set from Suspension Stuff
hey chris
you could take the shock out and flex it up until the coil is about to drop out (if you dont want retainers or drop out cones) or untill you are happy with the amount of droop. Then measure between the shock mounts and size the new shock accordingly
96 GQ coil/Cab
08 G6eT
Great idea.. It would be interesting to see how long a spring is unloaded compared to loaded..
Owner of
Westy's Accessories
