What On-Board Diagnostics protocol does your Patrol use
Also curious about my Uncles Patrol having the 2 plugs, was it a factory thing maybe when they were changing over or has a previous owner installed it.
Toddie
Toddie
I heard people change their 14 to 16 pin so his might have 2 in parallel.
From memory Chaz knows a bit on this stuff so he might see this at some stage
as far i can understand after looking right into it if you Nissan Patrol pre 2006 it has a consult system then in 2006 they changed the plug to a OBD2 but still used consult then common rail come along and now they use OBD2
