14th October 2012, 06:51 AM
$50 GQ storage boxes
Hey guys. I thought id share one of my DIY projects. My GQ needed some form of rear storage, having big plastic tubs strapped down in the back to hold all my recovery gear etc was just taking up too much room and all the bumping around of 4wding sees the boxes getting broken all the time. Not to mention the sub box I had in there with 2x12" subs taking up a heap of room!
I didn't want drawers as I need the height in the back for the kids bikes to go in and the potential to run the dickie seats is also handy with 3 kids.
So.....I decided to use the 'wasted' space over the rear wheel arches, by making up a storage compartment that also incorporates a speaker box.
First I stripped out the rear of the GQ.
![](https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-ash4/418087_10150550466671871_542945410_n.jpg)
![](https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash4/423150_10150550468316871_1364662598_n.jpg)
I refitted the RH side trim, it is out in this pic to run the wiring needed for the fridge.
Then I had to get the materials needed for the job. I bought....
3 sheets of MDF, 2x 1200x900x12mm thick 1x 600x900x12mm thick, 4 small hinges, 2 pairs of magnetic door catches, 2 handles, some right angle brackets, some screws and liquid nails. All the materials cost $50.25 at my local bunnings.
![](https://fbcdn-sphotos-b-a.akamaihd.net/hphotos-ak-ash4/405544_10150550473826871_588538034_n.jpg)
![](https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-ash4/393830_10150550478981871_1985003409_n.jpg)
I then transferred my plans to the MDF, I was able to make most of the panels required for one side from 1 sheet of MDF, the smaller sheet was needed for the partition and one of the ends.
![](https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash4/432340_10150550480996871_449558554_n.jpg)
Then I simply cut it all out, planed all the edges and screwed it all together and trial fitted it.
![](https://fbcdn-sphotos-h-a.akamaihd.net/hphotos-ak-ash4/396752_10150550483266871_1020772624_n.jpg)
![](https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-ash4/407796_10150550484736871_1817075472_n.jpg)
Then once I was happy with the fit of the main box, I then cut and fitted the end piece that is closest to the front of the car, which matched the profile of the wheel arch, and I made a divider, which also follows the profile of the wheel arch, to separate the storage box section from the speaker box section. Sorry, no pics of this but I can take if you want!
Then I fitted the magnetic door holders to keep the lids closed, the handles (which I now don't like!) and cut the speaker holes for the 6x9 speakers.
![](https://fbcdn-sphotos-c-a.akamaihd.net/hphotos-ak-snc7/421507_10150550487776871_34681132_n.jpg)
![](https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-ash4/428777_10150550490096871_1673862382_n.jpg)
All I need to do now is fit the power sockets once I work out where I want the fridge to go, and carpet the whole lot.
And the boxes dont look really big to look at.....
![](https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-snc7/421018_10150550492176871_24566778_n.jpg)
But just in the left one, I have 2 snatch straps, a tree trunk protector, winch controller, recovery blanket, 2 pairs of gloves, tow hitch recovery point, 2 ratchet straps, a couple of cans of various lubes and cleaners, bow shackles, some rags, the jack, jack handle and wheel brace. That leaves the RH side for things like spare oils, parts etc.
Thanks for looking!
The Following 5 Users Say Thank You to Devious 4x4 For This Useful Post:
AB (14th October 2012), NissanGQ4.2 (14th October 2012), rkinsey (27th February 2013), taslucas (14th October 2012), Woof (14th October 2012)
14th October 2012 06:51 AM
14th October 2012, 07:12 AM
14th October 2012, 07:17 AM
Thanks for that. They work well!
14th October 2012, 07:24 AM
Banned
Yep, functional and made on a budget. Well done mate!!
14th October 2012, 07:26 AM
Thanks mate. I do everything on a budget!
Administrator
I like it mate, leaves loads of room to store stuff in the back too!
14th October 2012, 07:28 AM
Look great that MDF stuff hates water. protect it some how?
I like the way you went full height.
Now more ideas ,power outlet , side speakers?????
14th October 2012, 07:48 AM
The MDF does not like water, but thankfully, I dont plan on sinking it! I do need to carpet them though. Since that project was done, Ive added a double power outlet with one outlet for the fridge and the other to charge a torch. It has speakers on the top of the box, so with the back fully loaded we can still hear the music.
14th October 2012, 08:07 AM
BIG & BALD
Great boxes, the Dev is full of talent , well done.
Sent from the secret chambers of our secret society, on a secret iPhone, with a secret pin code and eye retina scanning from a secret peep hole, just don't tell anyone OK, cos it's secret........
The Following User Says Thank You to MEGOMONSTER For This Useful Post:
threedogs (27th February 2013)
14th October 2012, 01:30 PM
Nice looking boxes mate. i think i may copy them one day
. Maybe you could find some real cheap gas struts from a wreckers so they stay open when your rumaging around in there?
Hello from Under Down Under!
