5th January 2011, 12:55 PM
Nasty Dog - Moderator
Coroners Report into Snatch Strap death
FYI, please read and take note of the findings everyone.
http://www.magistratescourt.tas.gov....2010_tascd_418
If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
The Following 2 Users Say Thank You to Woof For This Useful Post:
Bob (5th January 2011), nowoolies (30th January 2011)
5th January 2011 12:55 PM
5th January 2011, 07:55 PM
Administrator
Good read and hopefully a wake up call for some people or hopefully some people have learnt something, thanks Doggy.
The tongue plate has been joined to the RHS hitch by an external fillet weld around all four sides. It was evident water had accumulated at the closed end and caused corrosion. The extent of corrosion was consistent with what would be expected from sea water. Wall thickness had been reduced by corrosion from 4mm to 2.mm along the top of the RHS, 2mm along the sides and 1 mm along the bottom. Average loss of wall thickness would have been greater than 50 percent. On a pro rata basis gross trailer mass of 1.5 tonne would have been more than halved.
I found this part interesting too, not that you should obviously ever use a tow ball for recovery but interesting to read anyhow. 50% loss from corrosion over time is quite a lot.
5th January 2011, 08:06 PM
Bitumen Burner
The Dogman
Thanks Wayne. Very sobering thoughts.
5th January 2011, 08:11 PM
SUCH IS LIFE
Cheers Doggy. Hope people take notice and convey this kind of information to all 4wd drivers.
Clearly theres plenty out there not following safe/correct recovery procedures.
________________________
______ 2017 D-Max _______
5th January 2011, 08:16 PM
DX grunt
Very scary stuff, cold shivers went up my spine when I read it.
As you always say Ross, "Take care out there"...............................everyone please do it.
5th January 2011, 08:20 PM
Administrator
The scary part is a lot of people just simply don't know!
I had a friend about 6 months ago come up to me with a "brilliant idea". He had made up two steel plates that go over the tow ball for a quick recovery. Unfortunately I explained to this friend what can happen, etc and he was extremely dissapointed as he spent many hours designing and building the idea. He has been 4wding many times and just simply did not know???
5th January 2011, 08:22 PM
Bitumen Burner
The Dogman
If I can help one person remember to 'Take car out there', I'm more than happy.
The Following User Says Thank You to DX grunt For This Useful Post:
5th January 2011, 09:31 PM
I will be sending this to endeavour rally organises
5th January 2011, 10:33 PM
Moderator
It just astounds me that there are still people out there that actively educate people to use a tow ball for a snatch recovery. Damn those People. Let them stand in that bloody court and hear that explanation.
Check out my Toy -->
Rogue Dung Beetle
30th January 2011, 12:19 PM
HELL NO !!!!!!
