26th August 2012, 12:03 AM
I used oven cleaner and a scraper. Came off so easy. Just have to be Mindful of where your spraying it.
26th August 2012 12:03 AM
27th August 2012, 01:04 AM
Did this myself yesterday. Should have gone on here first. I got a steamer, hit it for a few seconds and it all came off, glue and all. It was a steamer for household cleaning and the tint was original- 7yr old.
2004 GU ST 3.0 DDi 2" Tuff Dog Lift, Warn 9000lb, Custom dual Batteries Redarc, Safari Chip + Snorkel, 3" exhaust, NADS, MBC, DIY can, PWR Int,+9" fan, 7" GPS-DVD-TV Igo8 and Ozi with 2cams,6.5" Kicker splits and 6x9", Pillar+ Racetech EGT-PSI, Heated seats, fixed compressor, Arduino dual battery and engine/OAT temp display, 3" Projected 50W HID's with halo DRL's........so far.
17th September 2012, 04:14 PM
Hey u all thanks for the input I now have 2 do rear doors & side windows has anyone had an issue doing around the Demister wires?
18th September 2012, 02:22 AM
patrolrulz
yes you can damage the demister.
ie-- remove the metal from it and no work any more.
power wont pass to allow it heat up.
seek pro advise and or quote.
IF IT'S NOT A NISSAN.
THEN IT'S A COMPROMISE
The Following User Says Thank You to Robo For This Useful Post:
patrolrulz (18th September 2012)
18th September 2012, 12:35 PM
Thanks Robo
R there any pros here looking would appreciate advice
18th September 2012, 01:42 PM
You need to use a steamer to get the tint off a window with demister bars and take your time so as not to take any of the bars off at the same time, depending on how old the film is it shouldn't be too hard, how old/crappy is the tint?
The Following User Says Thank You to Gabe For This Useful Post:
18th September 2012, 03:07 PM
#17
Gabe I guess it is as old as the truck 6 years the rear doors & rear side wins r RS lots of bubbles
18th September 2012, 04:13 PM
#18
You'll definately need a steamer to get it off then and you'll have to use a really fine grade of steel wool to get the glue off especially if the glue doesn't come off with the tint, might just be easier to take it to a tinting place and have them do it for you, if you were in WA i could help you out as i do it for extra crust on the weekends...
18th September 2012, 07:13 PM
#19
Thanks Guys I will seek a pro 2 do it reckon I stuff it up
18th September 2012, 10:25 PM
#20
Might be a good idea, depending on how badly bubbled it is you might still lose them because they might have to scrape the window....
