26th December 2010, 11:10 PM
gq water temp
can anyone tell me the right operating water temp as i have replaced the termostat also new radiator hoses top and bottom flushed radiator engine flush and new coolant as my gauge reads half way to 3/4 any help would greatly apricated
4x4 is a way of life the more you do the more you get
26th December 2010 11:10 PM
26th December 2010, 11:29 PM
Bitumen Burner
I'll check mine tomorrow, but it doesn't go above half, at the very most.
Ross
26th December 2010, 11:43 PM
Rotaredom
gauges are useless. Pretty sure ideal is about 80deg
27th December 2010, 12:54 AM
Mine does not go above half and that is running all day and just idles away when checking tracks. Last Sunday was 7 or so hours without being turned off. But as Tod said, about 80 deg is around the norm for most cars.
27th December 2010, 08:08 AM
It will depend on what temp thermostat you used as to what temp it will be regulated at & as for the gauge????? that are not known for there accurateness so if you question it do what most do & thats fit an after market gauge.
The Following User Says Thank You to patch697 For This Useful Post:
NissanGQ4.2 (27th December 2010)
27th December 2010, 11:53 AM
Rotaredom
patch697
how true, why didn't i think of that!
27th December 2010, 02:38 PM
thanks guys the informatio provided was very useful ,but also have found out that my temp sender unit has craped out that is why i am getting false readings from my gauge
The Following 2 Users Say Thank You to seaveiw For This Useful Post:
NissanGQ4.2 (27th December 2010), patch697 (27th December 2010)
27th December 2010, 07:58 PM
#8
Thanks for the follow up mate & im glad you got to the bottom of it.
27th December 2010, 08:23 PM
#9
Nasty Dog - Moderator
Just moved your thread to here so other members can find it if they have the same issue.
If any members require assistance in anything regarding this forum, just let me know via a PM and I will help you in any way that I can.
19th February 2011, 02:20 AM
#10
RIP - valued member and true gentleman of this forum that will be missed by many!
used to be concerned about guage creeping up above half at low speed with a/c on. Checked with radiator shop and auto leccie who both advised that is in the normal range for GQs and not to worry - pay attention when it gets past the mark.
I have bought a couple of kits from an electrical place that will beep when a predetermined temp is reached - plan to attach the sensor to an engine bolt for an audible alarm that does not rely on water in the system
