Results 1 to 10 of 12
Thread: Passenger Door on Ute stuck?
    Advanced Muzza's Avatar
    Jul 2010
    Hi all, 2000 gu 4.2 turbo ute passenger door is stuck.
    It only happened on Friday after my neighbour slammed it hard and I can open it.
    There's nothing stuck in it (like seatbelt etc)
    its obviously unlocked and both inside and outside handles just do nothing.
    I'm thinking of pulling the trim off to get into the latch but the door being shut may be a problem.
    Has this happened to anyone, or anyone got any ideas?
    Banned
    Yep & it was all in the door lock button. I had to take the trim off which can be a bitch with the door shut but not impossible & muck around with the button part of the setup inside the door & got it open. Once it was open gave everything got a good squirt & know more probs.
    Some how the part inside the door latch setup itself had jammed in the lock position & disabled both handles but with some mucking around I got it all working again.
    Hope this helps
    Paul
    p.s this also happened by a door slam
    WA Wheatbelt
    23 Post(s)
    If it's the lock, how about using a coat hanger down the side of the glass - watching out you don't scratch your tint?
    Jul 2010
    Great replies, thanks for your help.
    Ill give yours a shot first as this is the easiest. hehe
    Thanks Patch, If DXGrunt's idea doesnt work or i cant reach then ill have to pull the trim off.
  5. #5
    WA Wheatbelt
    23 Post(s)
    Quote Originally Posted by Muzza View Post
    Which ever one you choose, be careful of your eyes. Wear protection.
  6. #6
    Jul 2010
    Yes, I'm mr safety now.
    About a year ago my cousin was grinding a frame for the shed door and some metal flicked in his eye and came very close to loosing it.
    Thanks for looking out but after i saw that happened I'm all over wearing goggles, gloves, etc.
    Cheers mate.
  7. #7
    Banned
    Cheers mate.
    Smart Man.... Take it from someone with only one eye. Its not something you would live with by choice.
    Paul
  8. #8
    Jul 2010
    The old coat hanger trick worked guys, thanks Rossco!
    took about a hundred tries and had to be carefull not to scratch it but i got in.
    It was jarred a bit and tight, so sprayed the crap out of it like Patch mentioned and is working good now.
    Cheers guys.
  9. #9
    WA Wheatbelt
    23 Post(s)
    Cheers guys.
    No worries my friend. Sometimes the simplest things work. LOL
  10. #10
    Banned
    Cheers guys.
    Glad you got it sorted mate.
    Paul
