27th July 2012, 12:06 AM
You can scribe it then use small drill around inside of line then file, should be snug fit
27th July 2012 12:06 AM
27th July 2012, 09:13 AM
Boofa
Thanks alot TimE, I all ready have my bullbar spotties switch where you have put the ariel switch, I am installing a LED light bar on the roof rack I want to put the switch for that where you have got the sub tank switch, I am also putting Reversing LED's on rear of roof rack, switch for them to go next to original sub tank position, and finally Do you think that the Ariel up/down switch will have enough slack to reach the furtherest blank next to the original sub tank switch position?
I have not got room on the RHS as I have a High Idle switch in there,
Im trying to use up all the standard Switch positions before I start to make my own spots
On mine the aerial switch had plenty of cable length, would have reached any of the switch blanks in the console or the panel under the heater controls
The Following User Says Thank You to TimE For This Useful Post:
27th July 2012, 09:15 AM
adventurepaul
TimE......What did you use to cut the holes? looks quite neat, good job. Ive since run out of switch room too and looking for more.
Mate, I'd like to claim the talent to cut such nice holes, however they are there from the factory, just had blanks in the spots I put the switches.
3rd August 2012, 10:07 PM
are these switches from arb specific to the GQ, Nissan, or any car.
