20th July 2012, 09:46 PM
Hardcore
Offset
Just bought some 35s maxxis bighorns I'm running a 15x8" -22 offset if I get the same style rims will it be ok
20th July 2012 09:46 PM
20th July 2012, 10:05 PM
Should do but it is gonna rub simply because they are a larger diameter tyre.
20th July 2012, 11:16 PM
Hardcore
Yeah I expect the rub but I was thinking more offset would it be better?
21st July 2012, 12:17 AM
Moderator
I would not go any wider than a neg 22 mate. You start to put a fair bit of pressure on your CVs and drive train with a bigger offset
Check out my Toy -->
Rogue Dung Beetle
21st July 2012, 08:32 AM
That and if you go a bigger offset you can then have dramas with the tyre touching the outside edge of the guard before it touches the chassis in the rear.
21st July 2012, 08:56 AM
Banned
I've mentioned it a few times on here about something called the Ackerman Angle of the tyre/rim (google it). The larger the offset, the more we screw with this angle and it creates wheel wobble (not good for more reasons than just being a pain at the steering wheel) which people try to get balanced out, change bushes, etc, etc only to find the wobble is still there.
It's not overly common and seems to be vehicle specific (a mate has a patrol similar setup to mine, but has -30 or something and he gets the wobbles bad through 80k's to 100k's whereas I have -22 and don't; others have bigger offsets than that even and don't get wobbles, so not sure how it affects some and not others, but it does and should be at least considered when upgrading).
21st July 2012, 09:15 AM
Smart like tractor
I have a neg 44 offset on a 10 inch rim and I get the wobbles at about 60km
96 GQ coil/Cab
08 G6eT
21st July 2012, 09:29 AM
#8
I think we need a new member "wobbles" as we already have a "clunk"
22nd July 2012, 01:02 AM
#9
Hardcore
so there 35x12.5 r15 stay with the 15x8"??
22nd July 2012, 06:56 AM
#10
Yeah bud stay with the 15x8" they will work a treat.
