5th July 2012, 10:11 AM
Will 35's fit with 2 inch lift??
Hi guys,
I am looking at buying Used iron man 2 inch lift for my GU, 4.2L, just wondering if I will be able to fit 35's under it once fitted?
Or should I just get 33's to be safe??
Cheers!!
5th July 2012 10:11 AM
5th July 2012, 10:49 AM
5th July 2012, 05:56 PM
35's scrubbed on a mates gu with a 3 "lift and i tried his 35s and i have a 2" and it rubbed on the front mud flaps and on the fuel tank filler plastic inner wheel guard and on body above the rear tyres the the guard can be heated and re- shaped and the mud flaps may be sorted with radius arm spacers not sure some one else can confirm this but there isnt much you can do about the body.
5th July 2012, 06:03 PM
You might get away with 3" lift with controll arm spacers, but would be close at the front mudflaps
