12th December 2010, 12:55 PM
TB42 Rocker Assembly help needed.
Can anyone help?
It sounded like we had a loose tappet so I took the cover off to adjust them.
All went well until the last rocker, it looks like there's a part missing on the shaft.
The rocker can slop back and forth on the shaft about 3.5mm, as if there's a wavy washer or a spring missing.
Looked at the workshop manual but it doesn't show anything. Anyone know what I need to fix it?
Thanks.
1989 GQ LWB Wagon, TB42 Petrol/LPG Auto. Bought Dec 2010
12th December 2010 12:55 PM
12th December 2010, 12:59 PM
Banned
Tony, Tim, anyone???? This sounds like a question for blokes who know what they're talking about ...
12th December 2010, 01:43 PM
I was really pleased to see I got a reply so quickly. Just a pity it doesn't help me much
12th December 2010, 01:56 PM
Banned
ripper
![Smile](images/smilies/smile.png)
Sorry china, I'm only on here for my good looks and witty humour!!! lolol ... a fair few of the others will be able to help no doubt though, wealth of knowledge amongst some of the lads on here ...
12th December 2010, 03:53 PM
Hardcore
Check the width of the rest of the rocker arms, maybe someone has mixed them up, I know that on the sd33 they all look the same but they are not, maybe there is a wider one that should be there, and the spring is taking up the difference on the wrong one, if you get my drift!! That is probably why nothing is shown in any manual as a shim or spacer.
Check also that the rocker is central over the valve at the tappet side and the pushrod is vertical.
The Following User Says Thank You to the ferret For This Useful Post:
ripper (12th December 2010)
12th December 2010, 04:38 PM
Sorry to be a bit slow responding, I've been down in the shed.
My manual shows 2 washers between the rocker and the 2 bolt pedestal, at least one of the washers is a wave washer.
Tony
The Following User Says Thank You to YNOT For This Useful Post:
12th December 2010, 05:36 PM
Thanks guys. Now I just have to find some. Anyone here got a collection of blown up ones?
Failing that, we've got a good engine reconditioner close, I can ask them.
Tony which manual are you using? I've got a factory one but maybe I missed the page which shows the washers.
12th December 2010, 05:38 PM
#8
I'm looking at a Gregorys manual.
It's also shown in the factory manual on page EM-23
Tony
12th December 2010, 05:58 PM
#9
Thanks Tony, I see it now, though it's a bit blurry, that's probably why I missed it.
19th December 2010, 06:20 PM
#10
yes mate wavey washer missing for sure.
