Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: build thread on td42 turbo
    Expert johno90's Avatar
    Moranbah QLD
    I have an update!!!
    Didnt get as much done on my holidays as hoped, i got new liners in and new pistons - heavy type with heat treatment and coating. o plus a 3" lift
    Things i have ordered this week are;
    20g td05 turbo
    turbo manifold
    water to air intercooler rated to be good for 600hp
    water meth injection kit
    and other bits to fit it all up
    Will get pics when stuff gets here and show install process
  2. #12
    North brissy
    Are you doing any flow work to your head there are good gains to be had just in that alone.
  3. #13
    Moranbah QLD
    Previous owner has had the head work done alrighty it was pretty obvious once i got it off, all i did was clean it up. The motor is pretty fast in n/a form pump is been worked and timing set and few other things, had a dyno of it at 115kw not much from the standard 96 but still not bad for n/a i think.
  4. #14
    22 Post(s)
    Interested to see how the water meth goes.. been thinking of that aswell at some stage.
    96 GQ coil/Cab
    08 G6eT
  5. #15
    Moranbah QLD
    yea so am i, ive heard lots of good reports about it. Plus the whole kit is pretty cheap for what your getting.
  6. #16
    22 Post(s)
    Quote Originally Posted by johno90 View Post
    its just illigal to have methaol on board apparently.
    96 GQ coil/Cab
    08 G6eT
  7. #17
    Moranbah QLD
    Depends on what state your in, wa i know you need a permit, in qld tho i havent heard anyone get done for it not even on v8's. i love the fact that i will be able to make 3d maps for each injector in the system.
  8. #18
    Advanced Lowy44's Avatar
    Watching this thread intently, as I too am performing the above modifications in the very near future
