12th April 2012, 07:44 PM
Apprentices Rule!!!
What fluid for clutch?
Hi all
Was wondering what the clutch fluid is for a 89 GQ tb42 as my lines are leaking
Cheers!
12th April 2012 07:44 PM
12th April 2012, 10:30 PM
Just some dot 4 brake fluid will be what your after mate.
13th April 2012, 05:32 PM
Apprentices Rule!!!
Thanks, I thought thats what it would be, just wanted a second opinion!
Cheers!
13th April 2012, 06:52 PM
Most likely it will be DOT 3.
Now we need a debate on whether you can use DOT 4 in a system that specifies DOT 3 ONLY.
13th April 2012, 10:03 PM
funny, i was just wondering about dot4 in a dot3 only. haven't got a clue.
13th April 2012, 11:57 PM
dot 4 is a better fluid i belive higher boiling temp etc same viscosity
14th April 2012, 12:35 PM
But a mix of DOT 3 and DOT 4 is worse than DOT 3 alone.
19th April 2012, 09:52 PM
^^^^ super true, mix dot 3 and 4 and it turns into sludge, if your going dot 4 then make sure you do a proper flush of the system.
21st April 2012, 07:49 AM
Apprentices Rule!!!
got some dot 3 thanks fellas
Cheers!
