I want to run
315-75-16 Tyres
Whats the minimum lift I don't want to do all the drop box panhard mods
Thinking maybe 2 inch suspension 2 inch body lift as long as they clear the gaurds.
I want to run
315-75-16 Tyres
Yeah mate 2 and 2 on a Gq to run 35s.
yep that should be fine. you might look at the radius arm spacer set to move the front diff forward as the 35s if they are brand new with deep tread will hit the back of the front guards and make a bit of a mess. Or trim your guards
Is this what your talking about http://www.ebay.com.au/itm/15mm-Radi...item43adea59e7
