Results 21 to 30 of 43
Thread: How big is too big?
    22 Post(s)
    Quote Originally Posted by Warnie View Post
    I also like the idea of big tyres small lift, for the same reason Benny said, in that it will be a more stable rig. Big lifts IMO are only useful in slow offroad situations such as wombat holes or areas where you need great articulation on a flat surface. On any sort of inclination great articulation just becomes dangerous as the risk of rolling increases exponentially.
    Not even slow off road mate, you stick a long travel shock in a small lift ( mine are over 200mm longer that a "standard" 4inch shock) you'll flex through most stuff
    96 GQ coil/Cab
    08 G6eT
    Patrol Guru Warnie's Avatar
    Apr 2011
    Muswellbrook NSW (formerly Brisbane SEQ)
    Ive gotta get a set of coil retainers and longer shocks. And maybe even use my rig more, its been pretty tame of late.
    They've done studies, you know. 60% of the time, it works every time.
  4. #23
    22 Post(s)
    yeah have a look at my set up next time we go for a drive
    96 GQ coil/Cab
    08 G6eT
  5. #24
    Advanced TD_Wagon's Avatar
    Ben-e-boy, Yeah mate Treps are tops! Have just about trashed the 35's but they have lasted over 2 years and 2 vheicles ha ha
    Big lift IMO is only good for ramp over angles and getting booked ha ha they would be good for like big arse rock crwaling and that though
  6. #25
    22 Post(s)
    Quote Originally Posted by TD_Wagon View Post
    yeah my prefered terrain is rock, I still think it too big COG is to high
    96 GQ coil/Cab
    08 G6eT
  7. #26
    Without starting a new thread once my cruiser sells i'll be upgrading my 31's. How do the fella go running 35's on stock gearing transfer/diff off road? I'm setting it up as a tough tourer and would like 35's but cant afford reduction gears to offset them so 33's are looking more appealing. Your thoughts?
  8. #27
    35s will be sloooowww!
  9. #28
    Sunshine Coast, QLD
    hey Dhuck,
    i too am from qld...have you had any unwanted attention from the boys in blue?? i currently have the 2' suspension lift and 31" AT...i am heaps keen to get a 3-4" suspension lift and possibly a 2" body lift and a set of 35"s?? but i also dont want to get any fines or something like that?? cheers
  10. #29
    Expert MudSlut's Avatar
    NW Tasmania
    What are the tyres in the first pic with the hell side walls?
    Matt, 91 Patrol 4 Door Ute, 8" of lift, 35's, Low ratio diffs, Spartan Front locker.
    Come Join my 4x4 club @ www.Trenchmen4x4.com
    Check out my Facebook page ----> Trenchmen 4x4 https://www.facebook.com/Trenchmen4x4
  11. #30
    brisbane
    Quote Originally Posted by MudSlut View Post
    maxxis Trepador
