Patrol is Dec 2000 made, complaince 2001 ZD 30 Automatic
It has the following.
3 inch Dobinson Springs and shocks
Superior Steering Link
Outback Interior Draws
Cargo Barrier with shelf and partion
2.75 Inch Beadusert Exhaust
Cross Country Intercooler
IPF Spotties with HID globes
NADS installed
Wholesale Automatics Valve Body
and probaly a million other things I have forgotten.
It is in getting a brand new zd30 installed. I am about to do a trip towing a 2 tonne van, so thought I would give it a birth day.
Is that a Stienbauer Module I see? How well does it perform with the exhaust? And also how much difference did the valve body make to the auto offroad?
Console was installed as I wanted a place for more switches with out cutting out the dash etc. Where the EGT and Boost gauge are was the Heat switch and Dimmer, moved them to where the cigarette plugs are. I also replaced that panel with later model, as it comes with 2 cigarette plugs straight up. It also had the electric antenna there instead of up near the stereo.
Some more things done/added
9 inch Head rest screens
VMS GPS
Focal Split Speakers for front and focal coxial for rear
Anderson connector for Caravan
Waeco 11 litre fridge in the middle of the rear seats
Waeco 39 litre in rear
Cruise control
Icom UHF radio
Still a little more to do.
Want to replace the sub tank
I have a LED light bar to put back on
Put on a solar panel for 2nd battery
Winch
When does it ever stop.
It is a Stienbauer Module on the console, I brought it at a premuim on ebay 2nd hand, only to find out it caused problems with Fuel Pump. So in two minds of trying it on the new engine and new fuel pump.
