1st February 2012, 01:46 PM
Daily Lurker
The Following 11 Users Say Thank You to rusty_nail For This Useful Post:
Bob (9th February 2015), damaverick (8th October 2012), JEDDAWY (29th February 2016), kevin07 (7th February 2015), MudRunnerTD (1st February 2012), ozzyboy (1st February 2012), ripper (12th April 2012), riskset (1st May 2012), swerver (11th March 2015), Trolatron (5th February 2012), tusman (7th February 2012)
1st February 2012 01:46 PM
1st February 2012, 02:21 PM
Thanks heaps for that nic. I think I will fit one in the near future. Where did you get it?
Hello from Under Down Under!
The Following User Says Thank You to taslucas For This Useful Post:
rusty_nail (1st February 2012)
1st February 2012, 02:22 PM
Banned
Top write up mate - well done!!
The Following User Says Thank You to Bigrig For This Useful Post:
1st February 2012, 02:32 PM
Daily Lurker
taslucas
got it off ebay... was soooooooo cheap, $130, from a seller who has been mentioned on here before, ponderosamustangco. it was shipped from the US, and it took 2 and a half weeks to arrive (but im pretty regional so cant blame him) well worth the wait tho
7th February 2012, 08:31 PM
Thanks Rusty nail, Did your instructions say anything about turning down a flange, I have recently brought a Pertronix kit and it says I have to do this? Thanks again mate awsome thred
Trollette, the angriest shorty in Victoria
![](image.php?s=272d033ac08c91facb70c7330047e8c0&u=4733&type=sigpic&dateline=1325229669)
7th February 2012, 08:57 PM
Daily Lurker
hey tusman,
no there was no mention of changing anything on the car, the reason for this was that if somehing were to go wrong with the unit, i would be able to just re attach the old "point system" as a backup. what kit did you get? mine was the Pertronix Ignitor 1762LS(lobe sensing).
cheers,
nic
The Following User Says Thank You to rusty_nail For This Useful Post:
tusman (8th February 2012)
8th February 2012, 02:52 PM
Thanks Mate, Mine is the pertronix 1762 (so I'm assuming it's not lobe sensing) and the instructions say the distributor must be removed from the car and a flange on the distributor shaft has to be Machined to 0.624 of an Inch. Other than that the instructions do seem similar to your post.
Thanks again
8th February 2012, 10:22 PM
Daily Lurker
yeah mate, the lobe sensing does not require machining. if i can suggest you take the unit you got back and see if you can replace it for lobe sensing unit. i thought this was essential as it maybe be annoying to replace and re-adjust points but when if somthing goes wrong and you have to buy a whole $xxx amount unit its way more expensive and risky...
tusman (9th February 2012)
9th February 2012, 08:18 AM
tusman
Thanks again
You have the Hall Effect (Magnet type and very reliable), the kit will have a black tube with green tape on it and a white tube.
The black tube has the magnets and has to sit over the lobes.
The flange just under the rotor button is a bit big and has to be machined down to let the tube slide down to the lobes, the white tube is a spacer that sits on top of the black tube under the rotor button.
The machining takes 5 minutes in a lathe, if you want to keep this kit and have problems getting the flange turned down PM me, I'll do it for free if you send the lobes piece to me with a return addressed envelope.
That goes for anyone on the forum.
Jeff
The Following 2 Users Say Thank You to jc58nc For This Useful Post:
jjgq89 (20th August 2013), tusman (9th February 2012)
9th February 2012, 03:28 PM
thanks for the feedback and thanks Jaff thats a very generous offer mate, I do have access to a lathe so should be right.
tus
The Following User Says Thank You to tusman For This Useful Post:
healy (11th November 2013)
