21st January 2012, 05:06 PM
rear drawers / dual battery
hey guys.
I'm knocking up some rear drawers for the gq. The drawers will house the sub / amp / speakers against mid row seats, and hopefully a duel battery in the rear. This leads to my question.
Has anyone built rear drawers, and set it up for a duel battery, in the wing on driver side?
The idea is to make the wings on both sides 250mm. Will this be wide enough for the battery tray / box/ battery?
In short, i am chasing width / length / depth of dual battery set ups.
any help appreciated here.
[IMG][/IMG]
cheers
ozz
21st January 2012 05:06 PM
21st January 2012, 05:15 PM
Daily Lurker
not sure on the dimensions, but i know trolatron built a really neat set of drawers for his SWB, the side compartments from memory did what you wanted to know, otherwise there are dozens of drawer setups and ideas for what you need, just do a forum search
The Following User Says Thank You to rusty_nail For This Useful Post:
ozzyboy (21st January 2012)
21st January 2012, 08:14 PM
Administrator
I'm only just guessing but I think you'll need 200mm x 300mm for the battery.
The 250mm gap your got is perfect but from the corner to the wheel arch will be definitely under the 300mm mark unfortunately.
The Following User Says Thank You to AB For This Useful Post:
21st January 2012, 08:18 PM
AB
yeah i was thinking that. I was originally going to put battery pasenger side, however wheel arch on drivers side dips down. I'm hoping a tray and sit above the dip in arch
21st January 2012, 08:30 PM
Administrator
ozzyboy
I think you'll only need an extra 80-100mm so you wouldn't really need the tray to be over the arch too. Maybe only an inch or so spacer off the ground would be enough and run the tray into the curve of the arch would be fine....If that makes any sense...LMAO
23rd January 2012, 09:18 PM
The Following 3 Users Say Thank You to Trolatron For This Useful Post:
NP99 (20th February 2013), ozzyboy (23rd January 2012), Parra (13th April 2012)
23rd January 2012, 11:12 PM
Trolatron
Like Rusty Nail said this is what Ive done to put my compressor on.You can see where the wheel arch is cut away.
The place where you want to put your battery measures 300 x 190 on mine which is just enough for a battery but you could sacrifice another inch from the daw width to make the gap wider if needed.
Ray
exactly what i was after.
thanks mate
ozz
29th January 2012, 01:54 PM
#8
Patrol Guru
ozzyboy looks like it will be a very neat setup, if i was going to put a second battery in the back of a vehicle i would try and use a sealed or gell type of battery, because they do not give off dangerous gases when they are being charged.
