first thing that came to mind was electrical loose conections or faulty soliniode
then todd mentioned gear shift might just be the button again electrical
glad i went back to manual
Found this in the manual, sorta sounds like your problem
Another thing I would check is the temp sensors on the valve body, when I had problems with my gearbox I found one of the wires on the temp sensor was broken.
taslucas (17th January 2012)
Definately more things to go wrong in an auto, but its not common for patrols to have this much trouble. Bad luck i suppose. Auto's are great for Mud hills, Sand, Rock steps....everything except down hills and simplicity!!! lol
Very close to biting the bullet and fitted the extreme valve body while its apart..........But still will have to fix the problem
Hello from Under Down Under!
Mate, I just installed that valve body, so when I get mine back and its actually running like it should, I can update on performance ...
And the downhill bit is more than solved with reduction gears - single best investment I've made (better than lockers for the amount you use them) ... mine crawls down hills now and if you get that valve body, you can get the manual torque converter lockup switch also and use it for engine compression down hill ... not as good as reduction gears, but a damn site better than standard.
Been talking to wholesale automatics they are nearly %100 certain that it is the temp sensor. I'm going to exchange the valve body for a extreme stage 2 and they will fit it with a new temp sensor. Fingers crossed it will fix the problem and be better than new!
hope so mate best of luck
taslucas (18th January 2012)
