Results 11 to 20 of 32
Thread: Interior light delay switch
    Beginner SCADA's Avatar
    Nov 2011
    Victoria
    Soooo how many people are interested in this? Its doable but will be a custom job. When I get my posts up I will down load the manuals and have a look at the wiring diagrams.
  2. #12
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by SCADA View Post
    Hey SCADA,
    You might be able to help me with another project.
    Some of the guys have asked about making their electric windows being able to work all the time, not just when the ignition is on.
    There is a 12 volt relay in the circuit that switches on with ignition, this supplies battery power to the windows, now you can just bypass this relay and supply direct battery power to the windows, but the problem is on the GUs there is a little LED light in the drivers side switch that stays illuminated when doing this.
    So I was thinking a timing circuit would be the way to go, it could keep the relay switched on for an hour or so after the ignition switch was turned off.
    What do you think?
  3. #13
    Nov 2011
    Victoria
    Should be pretty easy to do. Have heard this is an irritation on the Patrols. Does it effect GQ & all GU variants? Where is the relay? Interior or engine bay?
  4. #14
    Banned
    What about the timer shutoff relays the fords & Holdens run on there power windows?
    It doesn't last an hr but it lasts long enought to wind the windows up you realized you've left down after you pulled the keys out of the ignition...
    Just a thought.
  5. #15
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Both the GQs and GUs are the same, but from memory I don't think the GQs have the light in the switch, unless my old GQs one was just stuffed.
    The relay is inside the vehicle.
    Here it is in my GU, it's the blue relay top LHS
  6. The Following 2 Users Say Thank You to Yendor For This Useful Post:
    MudRunnerTD (15th December 2011), SCADA (15th December 2011)
  7. #16
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    Quote Originally Posted by patch697 View Post
    Just a thought.
    I'm not sure what Fords use but commodores from about VN on use the body control module.
    REDARC have a timer relay, that I think may do the job.
    http://redarc.com.au/products-and-se...tandard-timers
    But going by the prices on ebay they are around $130
  8. The Following User Says Thank You to Yendor For This Useful Post:
  9. #17
    Nov 2011
    Victoria
    Thanks for the info...$130 sounds a bit rich to me. How does everyone else feel about this?
  10. #18
    Hey SCADA,
    What do you think?
    Ummmm I know this is from the other forum but i thought it might possibly be useful............ well if your a member there that is (which I'm not)
    patrol4x4.com/forum/auto-electrical-37/power-window-override-button-66710/
    NOTE: DIRECT LINKS HAVE BEEN REMOVED DUE TO PATROL4X4's VIRUS PROBLEMS, ENTERING THE ABOVE LINK INTO YOUR BROWSER YOU DO AT YOUR OWN RISK
    KIND REGARDS
    FORUM MANAGEMENT
  11. The Following 2 Users Say Thank You to Clunk For This Useful Post:
    my third 256 (22nd January 2012), SCADA (15th December 2011)
  12. #19
    Banned
    Apr 2011
    Greenbank QLD
    25 Post(s)
    It sounds very expensive to me, for a timer circuit.
    That's why I thought I would ask if you could design a simple timer circuit that could keep the relay switched on for a period of time after the ignition was switched off.
    Jaycar also have a timer
    http://www.jaycar.com.au/productView...r&form=KEYWORD
    But is doesn't stay on for a long enough time I think.
  13. #20
    Nov 2011
    Victoria
    Quote Originally Posted by clunk71 View Post
    That would work OK but the best would be to have the option of both eh? Have a 5min (adjustable) delay after ignition off, and an over-ride switch to have it on all the time.
  14. The Following User Says Thank You to SCADA For This Useful Post:
    Yendor (15th December 2011)
