ok this might have been done before, but, what GU bits bolt straight onto a GQ?
what bits need a little fiddling around to fit?
what is not going to fit with out so much farking a round, that it's not worth the head ache?
troy
troy
G'Day Troy, AB(Andy) might be able to help you here mate, half his truck has been converted to a GU...LOLOLOL
I'm sure others might be able to help soon as well
________________________
______ 2017 D-Max _______
cool, at the moment, I'm after a power steering pump. mine has died a horrible death, and she's a bitch to drive with out it! especially with 12.5" tyres on the front
troy
Why would you want 2 put GU parts on a GQ?
cause GQ parts are hard to get in townsville and if I can get a wrecked GU for the right price it would be good info to have and maybe just maybe save me from swearing a lot for no good reason
troy
NissanGQ4.2 (21st November 2011)
Heaps of stuff mate other than panels.
I reckon the steering pump will go straight on. The GU diffs are considered an upgrade and sort after. They come with stronger internals and bigger brakes.
Most thing non body will be a winner if your looking for a wreck.
cool just got to find one and break the news to my 1st born son, he's gunna be moving out to whom ever I've got to pay
troy
MudRunnerTD (21st November 2011)
Yeah but it's for a good cause mate! He'll understand!
he's laughing now but not for long wait till i've got him out at the wreckers under a busted up troll hanging on to a spanner or something like that. then it'll be really funny ha ha ha ha ha look out for that joe blake
troy
Ok here goes, Steering box, Diffs, all control arms, body, springs, shocks, tailshafts, fueltanks,
Only thing with the diffs is you will need a adjustable drag link and you will have to retain the GU relay rod for the steering.
If it is a 4.8 then you will need to run 16 inch rims as the front calipers are HUGE!....unless like me you give them a bit of lovin then they fit good!...and do they stop!
Also some of the GU use a in-the-drum handbrake assembly so you will have to remove that to keep the GQ one. (thats what i did!)
gearbox is interchangeable but the shfter will sit back further, the transfers are exactly the same, unless of course it has the above handbrake which will mean there will be no hand brake drum on the back of the transfer.
thats about all i can think of at the mo!
Steve.
