"Gunter" - 1993 Nissan Patrol GQ DX II, 6cyl 4.2L Diesel. 2" Lift EFS suspension. 33" Mickey Thompson MTZ (285/75 R16). Warn Winch
Will have to try this as my gq flys down hills in low first and im always on the brakes
Works well indeed, used to use the handbrake in the bt50 in muddy uphill climbs and it gradually crawled up no issues.
Did the same in the patrol awhile back but the old " kirup syrup" mud down south ended up getting the better of the old AT's and bogged
Tap, Tap Taparoo
www.swat4x4.com
Sniko,
Have moved your thread fron General into the Gearbox section and also made it a sticky
Toddie
Great write up Bel, will have to try to remember what I learnt. Thank.
Publicly speaking to a private audience.
owenoldfella (28th September 2017)
I've used it previously, works well.
It probably does heat up your ATF a bit but maybe you just need to flush it a bit more regularly.
GUIII ZD30 Manual Wagon, OME 2" lift, 33" BFG AT's, Snorkel, Chip, 3" Redback Exh, Dual Batts, etc.
KEEP OUR TRACKS LITTER FREE!
