Results 1 to 10 of 13
Thread: Fitting AU Falcon thermo fans on GQ
    Advanced High_Mod_Performance's Avatar
    Jul 2011
    Drouin, Victoria
    Ive got a ste of AU Falcon thermo fans and was wondering if anyone has fitted them to their Patrol and what type of modifications are needed to fit them.
    i sat mine behind the radiator before i took the motor out and it looked like it was going to hit the water pump.
    Any help is greatfull
    Jamie
    Right Foot Down And We Are Moving
    Aug 2010
    Lower Blue Mountains
    17 Post(s)
    Sorry haven't fitted AU Falcon thermo fans, but have installed Davies Craig thermo fans ( twin ) 2 my patrol, here is a link 2 my pics
    http://www.nissanpatrol.com.au/forum...hermo-Fan-Pics
    My word of advice is to make sure you have a pretty good shroud around you fans as just having the fans themselves you may find your patrol overheating pretty easily.
    Nov 2010
    Getting a life...
    38 Post(s)
    Quote Originally Posted by toddrhind View Post
    Sorry haven't fitted AU Falcon thermo fans, but have installed Davies Craig thermo fans ( twin ) 2 my patrol, here is a link 2 my pics.
    Ther's no link, Todd..
    KATROL- The 2nd
    GU TD42TGi
    Silent member 1208
    Benarkin QLD
    Why do you need electric fans that flow less air flow than a factory clutch fan ???
    Heating issues ???
    OR
    Something else ???
    Jul 2011
    Drouin, Victoria
    im taking the viscous fan of, which will reduce drag on the motor and the twin AU thermos are going to be set at two different temps. i want to have more control over the temp of the cooling system, ive had my old GQ running too hot at first, i put a new radiator in and a diesel viscous fan and it ran too cold. i do alot of trips to the snow and i dont want it running cold. the AU fans have a good shroud and great airflow, the are used by a fair few of the boys i race against, and they are rear mounted aswell as front mounted
  6. #6
    Jul 2011
    Drouin, Victoria
    just to add the front mounted ones have a seperate tube frame from the firewall forward and modified to suit it
  7. #7
    Aug 2010
    17 Post(s)
    Thanks Kat, added 2 original post
  8. #8
    Quote Originally Posted by High_Mod_Performance View Post
    If your thermostat is working properly it shouldn't run cold.
    Setting up the AU fans as 2 speed is how they were set up in AU's. Run in series at low speed (so each fan saw 6 volts) and parallel for high speed.
    Tony
  9. The Following User Says Thank You to YNOT For This Useful Post:
    High_Mod_Performance (6th August 2011)
  10. #9
    Aug 2010
    17 Post(s)
    Jamie, PM XLR8, if you want some help / advice on AU Falcon thermo fans.....he runs twin AU/BA Falcon fans with a custom made shroud and thermostatic switch on his.
    Todd
  11. #10
    Todd
    Photo's of the custom fan shroud please XLR8.
    Tony
