Page 2 of 23 FirstFirst 1234 ... LastLast
Results 11 to 20 of 230
Thread: What Oil Do You Use for Diesel Engines?
    Sep 2010
    Hi all,
    I use 2 x 5L engine oil and a new filter from Nissan and change every 5,000km in my GU IV 3L.
  2. #12
    Sep 2010
    Hi,
    I use Penrite 15/50 Semi syn in my old 2.8 and she's changed every 5000km on the dot or before.
  3. #13
    Expert 89GQ's Avatar
    Adelaide South Aus.
    Delo 400 and filters every 5000 K's. Sh'es on 300.000 k's, and probably uses 200ml between changes.
    89 GQ TD 42
  4. #14
    Sep 2010
    another vote for delo 400
  5. #15
    Sep 2010
    Brisbane
    Delo 400 again, meets JASO-DH1 which I think is a Nissan specification for oil used in the ZD30?
  6. The Following User Says Thank You to Stewart For This Useful Post:
    patch697 (15th September 2010)
  7. #16
    Expert Chaz's Avatar
    Sep 2010
    Adelaide
    I’ve been using Mobil1 in 5W50 for the last 100K with a splash of AW10 at 10K intervals. There’s a noticeable improvement in the reduction of cold engine noise but it comes at a cost. Also running some 2T oil in the diesel fuel improved IP noise.
  8. #17
    Sep 2010
    Off Shore on Macleay Island, Near Straddie
    TRied different brands of oils. At the moment using Nulon 15 40. Sounds sweet and purrs like a kitten. ZD 30
  9. #18
    Oct 2010
    yep agree on the castol oil
  10. #19
    Adelaide South Aus.
    Quote Originally Posted by Chaz View Post
    That 2T's the go hey!!!!!!
    89 GQ TD 42
  11. #20
    Sep 2010
    Adelaide
    Quote Originally Posted by 89GQ View Post
    Yep, good stuff. I've been using it for over a year now and very impressed. You sure notice the difference when you don't use it, particularly when the engine is cold.
