24th July 2011, 11:27 AM
24th July 2011 11:27 AM
24th July 2011, 01:16 PM
I run the 4WD Systems Lokka in my Patrol ,aswell as in my Triton, and fitted it myself (plus several for others). I find it pretty reliable although I am aware of 3 that have spat springs and pins when given a real hiding. On every occasion 4WD systems have replaced the pins and springs at no charge. Follow the supplied instructions and make sure you are within tolerance (making sure to record them on the sheet provided for warranty purposes) and you'll have no problems at all.
Steering is still a bit heavy and at times the Lokka is a pain, mainly when it is too soft for 2WD but too firm to justify the Locka. A common fix is unlock the drivers side hub. If you have auto hubs, I would strongly recommend changing them out for manuals, you'll find that as time goes by the auto hubs get harder and harder to unlock.
Only other thing to watch is your driving style. The vehicle will drive differently and have a tendancy to pull left or right on slippery inclines. Alot less right boot will be required and be careful lifting wheels at high speed. Slam a wheel back to earth with the front spinning too fast and you'll kill a CV in an instant
Other than these little inconveniences best money I've spent.
The Following 3 Users Say Thank You to XLR8 For This Useful Post:
AB (24th July 2011), growler2058 (24th July 2011), Woof (24th July 2011)
24th July 2011, 01:32 PM
24th July 2011, 09:15 PM
Administrator
I need a front locker one of these days mate so If you do go about it then please wang up a DIY...lol
25th July 2011, 05:31 PM
SPAMINATOR
AB
Will do mate from what im reading it seems a relitively simple task fingers crossed
![](image.php?s=679f81dec1feb2f9f6348560b8455207&u=2058&type=sigpic&dateline=1604048275)
25th July 2011, 05:51 PM
Enjoying the trips
Very interesting, will be following with interest
Macca
10th August 2011, 04:57 PM
Hi, Could someone pls shed some light in reference to how ARB air lockers work? Do you just need air to engage and disengage them or do they have to have a constant air pressure e.g. from an air reciever to keep them activated. Reason for asking is that I have a black max air compressor that has roughly the same output as a CKMA12 ARB air compressor and want to know if i can use this to run air lockers or do i have to have an air reciever with a cut off switch? Thanks.
12th August 2011, 08:55 PM
#8
Budjen98
You don't need a air tank to get the lockers to work. They just run of the compressor with a pressure cut out switch. The locker needs at least 85psi to engage & the compressor will just run until it has that psi then stop. It will cut in & out to maintain the required psi.
The conspiracy theorists were right!
