Results 1 to 10 of 14
Thread: 2012 GU CRD running a little warmer than usual.
    Yea, Victoria
    I have a Ultra Gauge on my dash that, among other things, monitors my coolant temp. Lately it seems to be running a little warmer across the spectrum. Instead of ranging fro 86c to 89c depending on hills etc, it ranges from about 87c to 91C. It has never got to the stage that I was worried about over heating but it did make me do some basic checks. Mainly fluid level. My radiator was replaced about 12 months ago along with the thermostat and naturally the fluid was replaced at the same time. I am leaning on a new viscous fan hub. Its the original from when I bought the car in 2012.
    Is there any gotcha's doing this job that I should be aware of. I plan on using a genuine Nissan part.
    Cheers all.
  2. The Following User Says Thank You to Coldcomfort For This Useful Post:
    Touses (2nd December 2024)
    Hardcore jack's Avatar
    Ballarat Area
    26 Post(s)
    Mine always ran at the higher temps from new, never had an issue. Also a few degrees higher when towing, and we did a fair bit of that.
    Jack
    2024 Isuzu MUX
    Yea, Victoria
    I had some time this morning and did some testing of the viscous fan. Went for a about a one hour drive to get the engine proper warmed up. Shut it down and turned the fan by hand. There is no resistance at all. Does this confirm a stuffed coupler?
    Cheers all.
    477 Post(s)
    There should be some resistance. If its the original hub, its probably time to change it out.
    Coldcomfort (10th December 2024)
    Yea, Victoria
    It is the original one. I'll get this done soon. Thanks.
    Yea, Victoria
    New viscous coupler arrived Friday. I pulled the fan shroud and fan off. I have decided that since I'm this far down the rabbit hole I will also replace the water pump. I have just ordered a new genuine from Patrolapart. Should have it by about Wednesday. It doesnt look like too much of a hard job to replace the pump. Am I fooling myself? What is others experience? Good, bad, ugly? Cheers Brian.
  9. #7
    477 Post(s)
    I think there pretty easy if you have everything off and have easy access. While its apart i would be changing out the tensioner and belt, replacing any idler pulley bearings there may be and getting the radiator professionally cleaned. If they've never been looked at before....
  10. #8
    Yea, Victoria
    Belt tensioner was replaced about 12 months ago along with the radiator. So all good there. That's part of the reason I am replacing the water pump. Everything else is new so that may as well be.
  11. The Following 2 Users Say Thank You to Coldcomfort For This Useful Post:
    BrazilianY60 (17th December 2024), mudski (17th December 2024)
  12. #9
    Nov 2019
    Perth
    5 Post(s)
    I see up to 95-96 towing a trailer full of gear up a hill. Generally 87-89 around town. Have replaced the expansion tank and all the hoses and performed yearly coolant flushings, 225kms the hub and pump are original.
    2008 CRD Auto Wagon
  13. #10
    Dec 2024
    1990 Patrol workshop manual
    Hi Dear, could someone help with the repair Manual ?
