Removal of the center console fascia GUIV and later _ how much later not sure.
Was asked how to access radio so knocked this up and may help others.
To remove center fascia:
Step 1 _ First unscrew the two Phillips Head Screws.
Step 2 _ Grasp top parcel shelf and pull back towards yourself (give it a bit of a gentle tug) _ will unclip from top/removed.
Step 3 _ Can remove the two harness connectors (side clip depress and pull out).
Step 4 _ Put aside then remove the 4 Phillips Screw Holding the Radio in place and remove unit / unplug.
To replace _ reverse order.
For Fascia replacement:
Step 5 - First align/nest bottom edge in position then apply hand pressure to top area.
Step 6 - Push Top of fascia back in place then refit the two fastener screws.
Step 7 _ Back in Place.
