Results 1 to 5 of 5
Thread: Injector tubes.
    Yea, Victoria
    Injector tubes.
    Hi all, I am planning on replacing my rocker cover soon. (2012 GU CRD) I have all the new parts except the injector tubes. I have read that these are a one use item. I have also heard that they can be re-used. I know that mine have never been removed so far. Whats the general consensus on this? I'm happy (not really happy but willing) to buy new tubes but would rather not if I can avoid it.
    Cheers all, Brian.
    476 Post(s)
    They are recommended one use because the high fuel pressures that run through the lines. If it were me. I would remove them and assess the ends of the lines, they have a tapered section on them, if the taper is not damaged in any way, I would reuse them. Only because I'm a tighty.
    If one leaks then I would replace it.
  3. The Following User Says Thank You to mudski For This Useful Post:
    Coldcomfort (31st May 2024)
    Yea, Victoria
    Another question. How tight are these things generally screwed down? Is there a recommended torque settings? Cheers.
    Nov 2019
    Perth
    5 Post(s)
    I've reused the injector tubes multiple times with no ill-effect, just keep them clean. I replaced them after my last tear down for peace of mind.
    I just tightened them as much as practical, nice and firm. Unsure of torque specs, there's none in the manual for injector tubes.
    2008 CRD Auto Wagon
  6. The Following User Says Thank You to pollenface For This Useful Post:
    Yea, Victoria
    I bit the bullet and bought four new tubes. But I'll keep the old ones just in case.
  8. The Following User Says Thank You to Coldcomfort For This Useful Post:
    MB (2nd June 2024)
