Page 72 of 77 FirstFirst ... 7071727374 ... LastLast
Results 711 to 720 of 762
Thread: Jay see 1997 GU build up
  1. #711
    I'm happy with the flow and how it works, but I'm only getting the top part of the water out approx 20 lts with good flow, then it looks like it's sucking air.
    If the water is above the outlet level and the hose clamps are tight it can only be a hole in the hose or a hole in the diaphragm of the pump or a torn diaphragm I think? PIA issues, i feel for you.
  2. #712
    May 2016
    lower west victoria
    30 Post(s)
    Had a chance to have a good look today..
    So, the stupid design of this tank means that there are 2 outlets one at each end. What I tried to do is connect the 2 into one.
    While full it works good, 20lts later once the water is in its 2 separate compartments it coughs and splatters.
    Now I think I will run 2 separate lines, one at each end.
    While tank is full has good pressure
    https://youtu.be/_lb4AQ7LG50?si=Io0m6jwlEI-FR_bR
    I was going to suggest you simply flip it upside down, but then I saw the filler.
    I'd just leave some wiggle room and when the outlet side got low, I'd just lift it up and drain from the full side to the empty side, that's what I did with my bladder.
    Or just top the thing up, never a bad idea to circulate your water.
    KISS.
  3. The Following User Says Thank You to 10G For This Useful Post:
    jay see (12th May 2024)
  4. #713
    May 2024
    looking good mate hopefully have my 61 on the road this summer
  5. The Following User Says Thank You to walkies For This Useful Post:
    MB (15th May 2024)
  6. #714
    483 Post(s)
    Quote Originally Posted by walkies View Post
    Admin, Maybe Moderators
    Can we please dispose of Walkie Dangerous Talkie
  7. #715
    Haven't had much time this weekend, but squeezed in enough to finally get this water tank sorted. Once it was all level it pumps out about 35 litres and with a couple wedges in the right places I should be able to get the last few litres if needed.
    https://youtube.com/shorts/GWnyiKIAm...r2lPKRcuyXwNRt
    Now onto the next thing..
  8. The Following 2 Users Say Thank You to jay see For This Useful Post:
    BrazilianY60 (19th May 2024), MB (19th May 2024)
  9. #716
    178 Post(s)
    Take some spare plastic fittings with you.
  10. The Following User Says Thank You to Cuppa For This Useful Post:
    jay see (19th May 2024)
  11. #717
    Good outcome, however I think you would achieve the same flow just letting the water run out the hose. Anyway its installed and working
    jay see (20th May 2024)
  13. #718
    483 Post(s)
    Let us just say, gravity wins Apologies Brother but there is no need for fandagle water
  15. #719
    John, I assume the tank has a breather in the cap? If not it will suck in and stock flowing with either a pump or gravity. A small hole , say 3- 5mm dia would be fine, you could screw in a pneumatic airline fitting and add a small length of airline to raise the air point and also stop any nuisance splashing out of the take breather.
  16. The Following 2 Users Say Thank You to PeeBee For This Useful Post:
    jay see (20th May 2024), MB (21st May 2024)
  17. #720
    If the tank was sitting higher I wouldn't have gone with the pump, but we're only getting older so the convenience is nice to have.
    Yeah it did, but it's pretty shit. I'm going to replace it with a diff breather, something like the last pic..
  18. The Following 2 Users Say Thank You to jay see For This Useful Post:
    MB (21st May 2024), PeeBee (20th May 2024)
