Results 1 to 7 of 7
Thread: GQ Patrol headligh surround grill clips
    The GQ Patrol has 2 plastic clips either side that clip the grill into the front guards. I am trying to locate the name and a supply of 4 of these as mine are pretty shot and grill does not marry up tight with the guards. I am not talking about the 4 units that run across the top edge of the grill - I have replaced those with a metal clip and screw, and these work well.
    84 Post(s)
    I just cable tie the grill to the body, so that the bonnet clips I have mounted on the grill have something to anchor to.
  3. The Following User Says Thank You to mudnut For This Useful Post:
    MB (14th February 2024)
    482 Post(s)
    Would be honestly keen to learn their name, availability too Philstar
    I’m thinking about changing over from $$ OEM to maybe a Hills-Hack Rough-Job cheaper variant via Bunnings/Ramset WallMates sawn off after insertion
    Apr 2021
    Brazil
    My GQ has none and currently uses tie-wraps to hold the grill (very nice and tight I may add), but I recon there are two types, one black and one gray. On the GU it uses only a pair of the black ones and none of the grays. Not sure if one of those is what you are looking for.
    Black ones:
    https://www.aliexpress.com/item/1005...Cquery_from%3A
    Gray ones:
  6. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    Thanks BY60, these dont look like the ones I think I need - will pull one off grill next time I am with it - maybe I am wrong
    Could be a counter question at PAP I reckopn, or I try something like a hutsert but they are in a bugger of a spot to get to if trying to do a bolt up.
    Thanks Craig, I will look at this option also.
