Results 1 to 6 of 6
Thread: what's a turbo worth?
    Nov 2019
    Perth
    5 Post(s)
    I've been hearing a tinny rattling sound from the turbo area under boost for the last 3000kms and just cottoned on that it might be the turbo.
    Hypothetically, which direction should I go if a replacement is required? Is the OEM repairable? It's a CRD with 219,000kms & Garret GT2052V turbo.
    I've heard aftermarket (UFI) can be good for handling higher boost, currently running 18.5psi. Went to their website and can only find an OEM replacement.
    Is CCT a brand worth looking at?
    2008 CRD Auto Wagon
    Quote Originally Posted by pollenface View Post
    Take off the air inlet to the turbo and see if there’s play with the shaft first just to confirm that’s it turbo.
    There shouldn’t be any play at all.
  3. The Following 2 Users Say Thank You to AB For This Useful Post:
    BigRAWesty (11th February 2024), MB (11th February 2024)
    483 Post(s)
    Turbo nuffy here sorry Bro
    Thought that exhaust pressure applied was what took the ‘slop-slack’ out of turbines to properly seal. Remember test scenarios applying light air (psi) to mimic/gauge specific reasonable brands shaft shift
    483 Post(s)
    Talk about Karma
    My new turbo bolted to its freshly strengthened/rebuilt TD42 has just started squealing up the snorkel too PF Mate.
    I won’t mention brands yet as they’re honourably coming to the party but thought I’d explain above a little better.
    I believe the in/out/forward/backwards movement of the turbine shaft does have a slight allowance/tollerance for shift that can be tested on a work bench.
    When the turbine shaft is not properly centralised for whatever flogged out reason the turbo housing/casting gets clipped on rotation/spinning causing certainly my squealing issue very possibly yours too mate.
  6. The Following 4 Users Say Thank You to MB For This Useful Post:
    AB (14th February 2024), BrazilianY60 (14th February 2024), PeeBee (14th February 2024), Touses (15th February 2024)
    Apr 2021
    Brazil
    3 Post(s)
    What do you notice on this picture, specifically MB? Nothing seem to be scratching/interfering to my nuffy self.
  8. The Following User Says Thank You to BrazilianY60 For This Useful Post:
    MB (14th February 2024)
  9. #6
    483 Post(s)
    A Woeful iphoney picture agreed BZ Mate although wasn’t worth photographing my Milwaukee 12v inspection camera/screen clarity
    It is clipping its casting and has shiny witness marks towards the center. All under control and have decided to park old mate up instead of throwing vanes through its NEW beautiful guts
  10. The Following 2 Users Say Thank You to MB For This Useful Post:
    BrazilianY60 (14th February 2024), Rossco (15th February 2024)
