Results 1 to 7 of 7
Thread: Alternator not charging!
    Apr 2022
    Mornington peninsula
    Hey guys I'm new to this forum, I have a straight lpg RB30 turbo gq patrol that I bought about 6-7 months ago and the wiring under the bonnet was (and sadly still is) a fu*king mess and unfortunately I can't seem to get my head around it all,
    So almost 1 Month ago I got it stuck in a bog hole and the starter motor, alternator and basically the whole bottom of the motor sat in muddy water for a good 2-3hrs so as you could imagine the starter motor and alternator had to be replaced,
    So I purchased a second hand alternator out of a TB42 for my RB30, when I went to purchase the alternator the seller showed me that the alternator was charging at 14.3volts, so the alternator has the 2 pin plug with a yellow wire that has been piggy backed onto the thicker white/red wire that goes to a 100amp fuse and a grey/red wire that goes straight to the positive terminal on my battery
    Then I purchased a brand new starter motor from bursons and installed that but cause of the messy wiring for some reason with the factory wiring wired to the starter all it did was tick every time I went to start it, so I've had to run my own wiring to the starter so I have a wire that runs from the positive on the starter motor straight to my positive on my battery, then the black wire with the yellow strip runs into the factory loom and I lose it?.....
    But now my car will only start if I jump start it because it's not getting charge from my alternator the volts while the car is running is 11.7- 12 unless I'm driving the the volts gradually decrease until the car dies.
    If anybody can shed some light on what could be it's problem that would be awesome, because covering it in petrol and throwing a match at it is looking closer and closer every day 🤣🤣....
  2. The Following User Says Thank You to Chrisppy For This Useful Post:
    MB (6th December 2022)
    @Yendor & @EvilTwin
    84 Post(s)
    Have you downloaded the manuals? There are pretty good diagrams to read. You might have to test the existing loom for open circuits or incorrect wiring. If it is such a mess, I would probably rip out the alternator loom and redo it properly. But I am bit of a perfectionist.
  5. The Following User Says Thank You to mudnut For This Useful Post:
    Chrisppy (6th December 2022)
    Apr 2022
    Nah I will have a look now thankyou
    Yeah I would love to re do it but wiring isn't exactly my fortè haha I think that's probably why I'm having so much trouble
    Apr 2022
    Hey ive just had a look online for a downloadable manual but i cant seem to find one.
    can you possibly send me a link of somewhere to download one or even just a PDF just to view?
    thanks mate
    84 Post(s)
  9. The Following User Says Thank You to mudnut For This Useful Post:
    Chrisppy (13th December 2022)
  10. #7
    Apr 2021
    Brazil
    The lower than 14.4v charging could be lesser RPM that the alternator needs. Being it from a different engine, have you compared the pulley sizes?
  11. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    Chrisppy (13th December 2022), mihit (7th December 2022)
