Page 5 of 16 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 156
Thread: I want a GU 42 by Christmas 2022! - Options and discussions on buying a used GU TD42
  1. #41
    Feb 2021
    Having owned a td42 gq ute for years (was reliable as!!!) And stepped up to a gu crd St wagon mainly for comfort reasons on long trips the crd has proved to be a good motor in the 90k iv put on it so far!!!! (Car now as 255) and since having a custom remap done 2 years ago has more than enough power and has been reliable as for the most part. I do have catch can egr block boost controller etc though.
  2. The Following User Says Thank You to wagu89 For This Useful Post:
    taslucas (14th May 2022)
  3. #42
    Patrol God taslucas's Avatar
    Aug 2011
    North West Tas
    56 Post(s)
    Ok, ok... IF I happened to go look at a converted td42, what are the danger areas? Let's say everything looks neat, there are receipts and quality parts used. What are some good questions to ask?
    Also are there any gu models that DON'T make good conversion candidates?
    Sent from my XQ-AT52 using Tapatalk
    Hello from Under Down Under!
  4. #43
    Jun 2018
    25 Post(s)
    Check it's registered as a TD42. If it's not, you may have trouble registering and insuring it.
  5. The Following User Says Thank You to Cremulator For This Useful Post:
    taslucas (19th May 2022)
  6. #44
    Just check everything works . . Glow plugs work as factory plus ask for a cold start, tacho especially below 1000 revs, all dash lights like oil pressure fuel filter water trap, AC working, sure there's more can't think of right now lol. . .
    Also just pay a close eye on the standard of work eg wiring and general tidiness of it all. . .
  7. The Following User Says Thank You to Rossco For This Useful Post:
  8. #45
    Check really well where the engine mounts are welded to the chassis as well.
  9. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    Rossco (19th May 2022), taslucas (19th May 2022)
  10. #46
    Probably not quite right, but many folks complain about TD42 engines overheating their ‘water’ (kettle’s I believe called) Lucas Mate. Again, poor maintenance I truly believe, albeit they were designed poorly in their systems out of the factory (running on the razors edge even almost perfectly clean) but I do worry about converted ZD30 <> TD42 ones as they appear to have more troubles than most?
    Maybe there is a radiator difference or top and bottom hose modification flow problem, really not sure Mate
  11. #47
    FWIW: Flew into Mexico from Newcastle late last night, finally gave up trying to fix/find basic old school parts for the petroleum/electrical based Maverick GQ TB42 pimped up 45 after 2,000kms of horrible work Gremlins
    In fairness the torque monster 4.5L petty kept chugging at 1/10th peddle but was looking like taking a week to get home for Taco night
    Not being rude but my experiences of younger days running Toyoda 2F’s and Chev’s came flooding back
    TD42-T’s with the leastest of wires have never before let me down, touch wood 🪵
  12. The Following 3 Users Say Thank You to MB For This Useful Post:
    Hodge (21st May 2022), mudnut (19th May 2022), Rossco (19th May 2022)
  13. #48
    Aug 2011
    North West Tas
    56 Post(s)
    I think I nearly followed that
  14. The Following 4 Users Say Thank You to taslucas For This Useful Post:
    Hodge (21st May 2022), MB (20th May 2022), mudnut (22nd May 2022), Rossco (20th May 2022)
  15. #49
    177 Post(s)
    One tiny fragment of advice I can vouch personally is the gear chatter rattle the TD42's have down-low in the revs when taking off. This is normal!!
    Just about every TD i've driven does this.
    To the unknown, including my self when first drove it I thought the gearbox and/or the bottom of the motor was gonna fall apart any second.
    Don't know the science and physics behind this but don't be put off by it when/if you test drive one and this happens.
  16. The Following 4 Users Say Thank You to Hodge For This Useful Post:
    MB (22nd May 2022), Plasnart (21st May 2022), Rossco (21st May 2022), taslucas (21st May 2022)
  17. #50
    In summary "TDs are a good thing" . . .
  18. The Following User Says Thank You to Rossco For This Useful Post:
    MB (22nd May 2022)
