Results 1 to 4 of 4
Thread: Brake Light Switch
    Aug 2011
    River Heads Q
    4 Post(s)
    Brake Light Switch
    Have not posted for ages but have lurking to keep up to date.
    A common problem with GU and GQ's is the brake lights staying on. Most often caused by the broken little plastic insert that the plunger of the switch on brake pedal hits when braking. Photo attached of old broken and new part.
    Nissan in their wisdom want $38 for a replacement. Real cost would be a couple of cents.
    However, it was my lucky day when I was advised the a Honda part was identical and only cost $5. Guess which one I purchased. My son had same problem on his GQ and now GU and put a small bolt in instead of the plastic replacement.
    It took 30 seconds to fix with the new part.
  2. The Following 4 Users Say Thank You to Wizard52 For This Useful Post:
    BrazilianY60 (1st January 2022), MB (31st December 2021), mudnut (1st January 2022), pollenface (1st January 2022)
    Apr 2021
    Brazil
    That is a good tip, thank you.
    Another quick/cheap way for it is to use any bumper/interior panels plastic clips, either in their original form or trimmed to be flat. Took a quick look at my plastic clips assortment here, and I think any of these could do the trick. This is what I will try later when I put my GQ back together.
  4. The Following 2 Users Say Thank You to BrazilianY60 For This Useful Post:
    MB (1st January 2022), mudnut (4th January 2022)
    Apr 2021
    Brazil
    By the way, happy new year! Just realized that its still the 31st for me but its probably already Jan/1st for the good folks in Australia!
  6. The Following 3 Users Say Thank You to BrazilianY60 For This Useful Post:
    Cremulator (1st January 2022), Cuppa (2nd January 2022), MB (1st January 2022)
  7. #4
    Aug 2011
    River Heads Q
    4 Post(s)
    Yes they would do exactly the same and probably last longer
