Page 62 of 64 FirstFirst ... 6061626364 LastLast
Results 611 to 620 of 635
Thread: Rosscos GQ Rejuvenation
  1. #611
    TBH I can't believe it kept pulling bloody amazing those High Mounts really thought threre was no chance looking at that back wheel buried in the goo. . .
  2. The Following 4 Users Say Thank You to Rossco For This Useful Post:
    jay see (14th November 2021), Maxhead (13th November 2021), MB (13th November 2021), mudnut (13th November 2021)
  3. #612
    483 Post(s)
    Wossco’s Weekend Wecovery Thexy Twelve or Twenty Faw Thervices
    www.thexy1224thervices.com.au
  4. The Following User Says Thank You to MB For This Useful Post:
    Rossco (13th November 2021)
  5. #613
    483 Post(s)
    Legend, THANKYOU
    mudski (6th January 2022)
  7. #614
    Quote Originally Posted by aronsteinn View Post
    Good luck with the swap mate!
    Oi mate just download the manuals. You don't need 25 posts.
  8. The Following 2 Users Say Thank You to Plasnart For This Useful Post:
    Avo (13th November 2021), mudski (6th January 2022)
  9. #615
    And that is when he stopped being and astrofuckinaut n started reading the farming rules...like a lepper in a hand out colony
  10. #616
    Took a slight detour when on the road the other day and ended up at Roardrunner Offroad damitt
    . . Few snazzy bits for the old girl upgraded brake shaft for the HM some new rope & hook and finally got myself a big black dildo to strap on the front. . . Did notice she got unusually hot on one of the scorchers the other day and looks like front of air con condenser still pretty dirty from $1000 dollar track so as brake shaft was on the cards may a well get bar, grill and intercooler off to give a good clean from front side and hopefully all good . .
    Also found windscreen leak that has plagued me since the rebuild had replaced all scrivets thinking that was it but still no good. . Looks like windscreen seal so at least its tracked down bit so should be able to get it sorted
  11. The Following 7 Users Say Thank You to Rossco For This Useful Post:
    AB (29th January 2022), jay see (28th January 2022), MB (28th January 2022), MudRunnerTD (29th January 2022), mudski (29th January 2022), Touses (31st January 2022), Winnie (28th January 2022)
  12. #617
    Ah where you be without a big black dildo in Christmas hills - I guess there isn't much else to do out there after you have strummed your way thru the same tooone 69 times!
  13. The Following 4 Users Say Thank You to PeeBee For This Useful Post:
    AB (29th January 2022), growler2058 (30th January 2022), MB (28th January 2022), Rossco (28th January 2022)
  14. #618
    Now that's a hook I'd like to trudge through swampy Tassie mud!
  15. The Following 2 Users Say Thank You to Winnie For This Useful Post:
    MB (28th January 2022), Rossco (29th January 2022)
  16. #619
    334 Post(s)
    Nice one mate. 12mm rope for the win. Awesome. What diameter us the dildo? Check out Markys. I highly recommend replacing that bottom bolt with a pin and clip so you can take it off while.commuting. winner.
    You will be impressed with the brake shaft too. It wasn't until.i fitted one that I realised how much of an upgrade it was, not just a circuit change.
    We need to get that 24v pumping mate!!!
  17. #620
    334 Post(s)
    You probably won't fit 40m of 12mm on your drum either. When I make the soft shackles I needed about 3m of 12mm per shackle FYI or.make a 10m extension strap (well 7m by the time you splice a loop in each end. Nice fluoro Orange for the win
