Results 21 to 30 of 34
Thread: New winch needed or not??
  1. #21
    Neither, in cab. I can hear the solenoid clicking even when the motor isn't moving
  2. #22
    82 Post(s)
    Maybe the solenoid contacts have carbon on them, or have been misshapen by excessive heat.
  3. #23
    Maybe...
    I got no f@#ken idea.
  4. #24
    198 Post(s)
    @jaysee, its only on the wrong terminal when you let the smoke out! Looks like just another small problem to resolve, good luck.
  5. The Following User Says Thank You to PeeBee For This Useful Post:
    jay see (17th July 2021)
  6. #25
    Did some more testing today.
    1st.
    I tested as per the video that pb put up and no difference.
    2nd
    I tested the solenoid.
    Hope it makes sense.
    Conclusion. Which runva to get..
  7. #26
    Expert Brissieboy's Avatar
    Jul 2015
    Brisbane, Qld
    10 Post(s)
    If you are satisfied that it is the contactor/solenoid, I have this Warn one that you can have if it is suitable. It is out of a 10,000lb unit that the gears failed after only a couple of minor uses but a lot of water ingress into the winch (but not the controller).Warn contactor.JPG
  8. The Following 4 Users Say Thank You to Brissieboy For This Useful Post:
    Avo (19th July 2021), jay see (19th July 2021), mudnut (19th July 2021), PeeBee (19th July 2021)
  9. #27
    Quote Originally Posted by Brissieboy View Post
    Thanks Brissie, but I think I'll be going a new everything..
  10. #28
    176 Post(s)
    I have the 13XP premium which are low in stock everywhere from what I understand. Great bit of kit.
    But 11 should suffice too .
    Look at the specs on the website and make a call from there.
  11. The Following User Says Thank You to Hodge For This Useful Post:
    jay see (20th July 2021)
  12. #29
    82 Post(s)
    If you are going to get rid of your current winch, and control gear, maybe at a meet up, I can grab it off you for a price and have a go repairing it. I've wanted to tear down a Runva to see how different it is from my Aldi unit.
  13. The Following User Says Thank You to mudnut For This Useful Post:
  14. #30
    I sent runva an email asking if the 13xp would fit with my Raslarr bar.
    Thank you for getting in touch.
    I don’t think the 13XP Premium will fit unfortunately. The 11XP Premium will however fit perfectly and a great option for a GU patrol.
    Is it correct that you the winch capacity should be double the weight of the car?
    I'll probably keep the solenoid as a spare, I didn't think that there's anything wrong with it and the rope as it's only been used to pull out a couple of yaccas, but you're welcome to the winch for nothing.
    I know a few years back the ALDI winch was the same as the Ironman. My current one is a t-max winch the runva is what I'm going to replace it with.
